Where is the ECM located?
Jleebee1975
Can anyone tell me where the ECM is located on a 2000 Land Rover Discovery 2? I am still having the problem with the crankshaft position sensor code. A few months back the dealership replaced the ECM in my truck and im wondering if maybe the wiring harness was damaged or if the connectors are loose.
The engine control module (ECM) is located on the RH side A post below the face panel inside the vehicle. It has a cast aluminium case and is mounted on a bracket. The ECM has 5 independent connectors totalling 134 pins.
  • joey
Dandavies9
