White, steel, Defender-style 18" wheels for LR4?
Bryan Jones
The guy with the 35's
Ohio
Maybe i misread your post. I thought you just said that putting 35s makes it unable to turn. So i CAN put 35s and still have all proper functionality without hacking to cut up my car to make them fit?
No. If you put 35's on you will need to do heavy modifications to the truck. I was jokingly saying that if you never plan on turning, then go ahead and put 35's on. But if you want it fully functional, then get ready to hack away
hatch
Pennsylvania
My understanding is that you can run TuffAnt, Terrafirma or Compo 18s and 265/60/r18s with full functionality. Does anyone know this to be untrue?
That essentially gives you the stock overall diameter, so yes.
Bryan Jones
Ohio
From what I've been reading, that's 100% true. Full functionality with no mods
Socialseb83
Houston
Do we have pictures of this setup?
Socialseb83
Houston
Also, does this provide for good/desirable sidewall?
hatch
Pennsylvania
Getting pretty close to pulling the trigger on the TuffAnts. I like the styling of the Terrafirma wheels better, but don't really want to run spacers (why I don't want to, I can't say, as I have exactly zero experience with spacers).
Nechaken
Colorado
I'm running Tuffant with 265/65/18. (So, bigger than your 265/60/18). Only "mod" for that was removing the plastic exhaust shield and storing the spare tire mostly deflated. No mods to wheel wells.
You should not need to do even that for 265/60/18.
Nechaken
Colorado
You should not need to do even that (deflating spare) for 265/60/18.
Edit: Not sure what happened with the double posts.
