Will not start
taxchecker
My 95 Disco all of a sudden will not start. Is getting fuel, is firing properly, acts like it almost catches but will not fire up.110 ,000 miles. what to check next..could it be the injectors?? what operates the injectors? Thanks for any input.
I would check the crank position sensor first, but are you sure your getting fuel? try a little starting fluid.. if it starts, then you have a fuel problem.
Could also be a bad distributor cap or rotor button.
PE_in_UAE
