Wiper fluid
MIKWIL
I got a 97RR my wiper fluid won't come out, i thought the holes might need to be clean out so i stick a straight pen down them but nothing. I disconnected the hose and nothing came out. What else can I look at? it sounds like it works the wipers move when i push the buttons and the back one works fine
Help pls,
Thank you in advance
Slam
Supporting Member
Supporting Member
You can try getting someone with pressurized air to blow out and junk... I did something similar once to clean out some a/c lines.
Have someone turn on the washers and listen to see if the pump is even running... could be a bad fuse or bad ground.
rnzslzr
