Quijote
I've been preparing myself for this work for some time. Our LR4 is at 8 years and 48k miles (August 2013 build). It's a bit early, but what the heck. We'll probably put under 5k miles per year going forward, so might as well. I do have a VERY small coolant leak that I assume is from the pump, but can find no trace. It seems to need about a cup every 2+ years. So it's not without some reason that I plan on this work. Plan is to do both crossovers, pump, and thermostat.
I've been saving related threads:
A few comments as I ready myself to order parts:
1. Here is my list. I found that LandRoverParamus consistently had better prices than Atlantic British and I didn't have a good experience with them last time. See parts list and Paramus' lower prices below (all parts are Genuine LR OEM):
Has anyone shopped there before? Am I missing anything obvious?
2. For the fan clutch, what is a better set? This: https://smile.amazon.com/gp/product/B000NICENU/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1 , or this: https://smile.amazon.com/gp/product/B0076PBXSU/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&th=1
Thanks!
I will try to document as much as I can just in case it can help someone in the future.
DIY water pump and crossover pipe Video.
Figured I would post this up in its own thread. Hope this helps at least one of you DIY your own water pump. I posted all the part numbers in the video description, most parts were sourced from amazon or eBay. Sent from my iPhone using Tapatalk
www.landroverworld.org
V8 Coolant Manifold / Crossover & Maintenance Parts List
Does anyone have a complete recommended parts list for replacing the coolant manifold / crossover pipes on a 2012 V8 LR4? I found this list in one of the threads, but no confirmation as to if this was accurate. LR018275 - Tube Water Outlet LR109402 - Heater Manifold Tube LR011038 - Bleeder Cap...
2016 LR4 Coolant Crossover, Water Pump, Thermostat Replacement
Thought I’d share (yet another) report on the coolant crossover issue. I have a 2016 Landmark Edition (service date was April 2016 I believe) with just over 50K miles. Took it to the dealer three times (two different dealers) prior to warranty expiration for coolant odor, but no leaks were...
Crossover Pipe Bursted on V8
Hi Guys. Well...the crossover pipe bursted while I was driving on the freeway today. I procrastinated on getting them replaced, so no one to blame but myself. I just hope the engine is OK. Long story short...I was driving along the freeway and noticed that my AC suddenly stopped blowing cold...
Bleeding cooling system
I have a 2011 Land Rover LR4 HSE I'm having problems bleeding the system I've tried about everything I need some help please
Belt | $40.61 |
Product ID: LR012663 | |
Fuel Injection Throttle Body Mounting Gasket | $7.17 |
Product ID: LR011999 | |
Serpentine Belt | $51.91 |
Product ID: LR064185 | |
Thermostat Unit | $74.21 |
Product ID: LR032135 | |
Water Outlet | $57.25 |
Product ID: LR018275 | |
Water Pump Assembly | $208.94 |
Product ID: LR097165 | |
Oil Cooler Tube | $23.54 |
Product ID: LR028136 | |
Oil Cooler Tube Seal | $7.27 |
Product ID: LR030593 | |
Water Manifold Plug | $4.58 |
Product ID: LR011038 | |
Engine Coolant Outlet Flange | $95.63 |
Product ID: LR109402 |
Thanks!
