LR3 battery choices for 2005 HSE
mtbutler93
What are my options for a non-OEM LR3 battery for a 2005 HSE and where's the best place to buy?
Thanks
The Interstate MTP-H8 is an identically sized replacement for the OEM, down to the location of the socket for the little pressure relief hose... :smile: In fact, were it not because of the color of the battery (the Interstate is white), you'd think it's an OEM. But the MTP has better CCA and reserve capacity numbers than the stock battery, so at least on paper it should perform better and last longer. I paid about $150 for it at a nearby Firestone tire dealer, they had to special order that size as it's not very common but it only took them a day to get it. Remember that if your car is still under factory warranty, the dealer will give you a new one FOC should yours be dying.
drzjoint
I migght have an interstate when the dealer replaced my batt they did it with a white one I just figured they changed colors from 05 to winter of 07
Ill have to check
davez26
Replacement batteries are the Interstate MTP-H8. Interstate has been the authorized replacement battery for Land Rover product since I can remember. Get it from Firestone, Interstate, or even your dealer! Pricing is all over the place on batteries lately.
Don't go cheap on these! The car takes a lot of power to operate the electrical architecture. As always, a quality purchase may cost more @ the beginning, but will usually last longer and perform more reliably thatn saving a few bucks today.
lfr
here we get better warranty for interstate
