Parasitic drain / Battery Monitoring
greiswig
Supporting Member
Supporting Member
SW Washington
Nearly 1/4 amp does seem a bit high. Have you double-checked that reading using your regular meter, just to make sure the clamp meter is accurate at low currents?
TimVZ
Iowa, USA
No, that is good idea though. Thanks.
On another note, I was able to perform the BMS test. It told me that my vehicle is not going to sleep properly AND that the wrong battery is in. It is expecting a 950/85 battery and what I have is 850/80.
Is there a means of updating or changing the battery via the scanner?
txfromwi
When ordering a new Exide 151, order it directly from the UK. even after shipping it will be considerably less expensive that getting one at a dealer.
I have been very pleased with Groves Batteries Ltd. Cheltenham.
When re-installing, note that factory OEM has a battery blanket that you most likely don't have anymore because the previous battery changes didn't take the time to re-install.
I go through the main battery specifications, and the battery reset with the IID Tool, and show a quiescent drain current table. I have never had any issues with the replacement batteries I have used, and I do discuss in the video the delta between OEM battery and the batteries we can get here (US).
bettingerg
