Nearly 1/4 amp does seem a bit high. Have you double-checked that reading using your regular meter, just to make sure the clamp meter is accurate at low currents?
No, that is good idea though. Thanks.Nearly 1/4 amp does seem a bit high. Have you double-checked that reading using your regular meter, just to make sure the clamp meter is accurate at low currents?
