dry_fly
- Joined
- Apr 10, 2006
- Posts
- 127
- Reaction score
- 0
what's the specs on the replacement washers?
Can royal purple or amsoil fluids be used in the Transfer case verses the Shell TF0753?
Mike,
Are you saying that you're OK with using aftermarket fluids in the diff & t-case?
Ugh!
You guys are going to wear me down to to point that it's easier to to just give the instructions.
Front Differential:
1. Remove engine skid plate
2. Clean area around drain and fill plugs, remove fill plug
3 Remove drain plug, drain fluid
4. Install drain plug; up to serial number 254845, tighten hexagonal drive drain plug to 54Nm (40 lb-ft), from serial number 254836, tighten 3/8" square drive drain plug to 28Nm (21 lb-ft)
5. Fill with 0.61 litres (1.07 pints) (0.64 US quarts) Castrol SAF-XO - 75W/90 (LRN 7591)
CAUTION: Do not use the fill plug as a level, fill with the correct quantity
6. Tighten filler plug to 34Nm (25 lb-ft)
7. Reinstall engine skid Plate.
Rear Differential:
1. Raise and support vehicle
WARNING: do not work under a vehicle supported by a jack
CAUTION: Do not undo or remove the large protruding hexagonal on the differential casing.
2. Clean the area around the differential fill plug and drain plug, remove the fill plug
3. Position container to collect fluid, remove the drain plug. Drain fluid
4. Install drain plug. Up to differential serial number 254325, tighten the hexagonal drive drain plug to 54Nm (40 lb-ft) from differential serial number 254326, tighten the 3/8" square drive drain plug to 28 Nm (21 lb-ft)
5. Refill with correct fluid and quantity;
Open unit: Castrol SAF - XO 75W/90 LRN 7591 1.1 Litres (2.3 US pints)(1.16 US Quarts)
Electronic torque managed differential: Castrol SAF Carbon Mod Plus LRN500070
1.5 litres (3.17 US pints) (1.6 US quarts)
CAUTION: make sure correct specification and quantity of oil is used
7. Install filler plug and tighten to 34Nm (25lb-ft)
Transfer case Draining and Filling
1. Raise and support vehicle (note the warning)
2. position a container to collect fluid
3. Clean area around fluid drain plug, remove plug and discard the sealing washer.
4. Allow fluid to drain
5. Clean component mating faces, install a new sealing washer, install drain plug and tighten to 22Nm (16lb-ft)
6. Remove the filler/level plug, clean the immediate are and discard the sealing washer
7. Refill transfer case with Shell TF 0753, LRN0753, until the fluid is level with the bottom of the filler/level plug hole. (1.5 litres)(2.6 US pints)(1.5 US quarts)
8. Install the fluid filler/level plug with a new sealing washer and tighten to 22Nm (16l lb-ft)
Not a difficult job. You will need some kind of pump to get the fluid into the filler holes. The discount auto stores sell a cheap pump that screws onto the oil containers. Be prepared for a lot of leakage if you use one of these things
Transfer Case: Royal Purple Synchromax (part #01512, quart bottle) or Royal Purple Max ATF (part #01320, quart bottle); 1.6 quarts
Differentials: Royal Purple Max Gear 75W-90 (part #01300, quart bottle); 0.65 quart for the front and 1.6 quarts for the rear (locker)
Thank you for all the details!You would do well to up-grade toa an 85W/140 oil for better wear protection and quieter gears.
This is made as a regular gear oil and a synthetic, you will nee 7 quarts to do the 3 units.
