Possible to upgrade me HSE basic 240 watt HK stereo to l7 one at dealer?
ougrad1
I used the jl audio cleansweep for SP. I'm running the jl audio hd900 amp, focal krx2 fronts, focal access coax rears and jl audio w3 sub. I had all of this from my last vehicle but if I replaced something it would be the cleansweep. I would consider the Jbl ms8 or the audison bit-one. I created a ppst on my install if you do a search, you should be able to find it.
johnnie
Thanks OU Grad. I did find the ppst, which is also very helpful.
The Audioson Bit One has been very favorably reviewed, so I'm inclined to go with it. The only downside is the closest authorized dealer is 60 miles away in Colorado Springs. For some reason, there is not a dealer in the entire Denver metro area.
ougrad1
Hey Johnnie...I wanted to see if you ended up going with the bit-one and if so, how do you like it?
johnnie
Haven't done it yet. The closest dealer is 60 miles away in Colorado Springs. Hopefully, I'll be able to head down there soon and get it done. Thanks again for the info.
DoornbosH
