LR4 Radio keeps going out!
ajclay1
Hello All,
4 times in the last week when I have started up my new LR4, the radio either worked for a little bit and then went to static or would only play static. The interesting thing is when i turn the car off and then back on, the radio works fine. Has anyone else experienced this problem and know what the fix is?
Thanks
Al
mateored
I had that happen once. No idea what causes it. Seems like a software glitch that should be fixed through some sort of update.
uhur
I've had it happen once in 4 months of ownership and 3k miles: the screen and everything on it went dead. I restarted the car after 5 minutes and everything worked fine since then
suvowner
just do a reset...remove the battery negative cable for a couple minutes......no radio software updates since 12/2010, per my dealer today......
gfcronus
Banned
Thanks
Al
Everyone who owns a Land Rover has experienced this, apparently. It's called OWNING A LAND ROVER. The fix is to own something else, anything else.
TangoRed
You need to just push for your dealer to replace the unit. From what I've gathered, that's the easiest fix.
I know you're considered a troll, but I'll bite. Go to any vehicle forum where the car model as a multimedia/nav system. You'll see this exact same problem. I even saw it when I was researching Lexus LS460s, a car widely known to be the most reliable in the luxury market. I'm not sure why this issue effects so many cars across so many makes, but it does.
socalrovershop
there is actually a software update that has been out for a while already . its a bulletin
horacioad
I'm on my third LR and nevar had that problem. Is the lack of problem the problem? Maybe I should trade one of the trucks since I am feeling left out. Maybe I am not good enough to have a LR with this issue!
suvowner
mine is doing it again lately, i won't take it in unless i can confirm a software update, otherwise will be a waste of time. i e-mailed the dealer waiting for response.
MArsel
