Passenger Seat wiring info
Xrover
Hey all,
2006 LR3 HSE 74,000 mi.
Does anyone know where the connection or sensor is located for the Passenger Seat SRS/Airbag system?
Here's the issue;
I had to move the passenger seat forward as well as tilt the seat back forward to make room for a bunch of boxes and stuff I was cramming into the cargo area. All rear seat backs were folded forward. I also had about 5lbs. worth of books on the front passenger seat.
When I started the vehicle, the dash made a chime and the red air bag warning light came on. Also, the Pass Seat air bag off indicator on the console turned off at the same time.
I removed the books from the passenger seat and moved the seat back to it's normal position but now I get the red warning light and chime on the dash every time.
Troubleshooting 101: "What was the last thing I did right before the problem occurred". Moved the seat.. Most likely a loose or pulled electrical connection right?
Rather then randomly poking around at all the wiring under that seat, I am hoping someone can point me to the location of the air bag/ occupancy sensor wiring and connection portion under that seat.
Thx !! :biggrin:
ryan-in-oregon
If you pull the plastic cover off the front of the passenger seat there is a large harness connector with a bolt in the middle of it. If the bolt is loose it is possible the connector came loose. However if that bolt/screw is still tight I doubt that is the problem. Worth a quick check though..
Xrover
The bolt was tight.. Well sort of tight. I tightened it some more and now it's loose. I think I might have pulled the captive nut out.
Car wouldn't start this morning so now I'm working on that issue.
Xrover
I reinserted the captive nut and reconnected the harness. No change to the problem.
I don't think it's pure coincidence that the pretensioner or seat sensor died at the same time i moved the seat all the way forward.
Most of the electrical issues I have had on this car were due to a loose or corroded connector. Dealer wants $130 just to hookup their code scanner. Any suggestions?
ryan-in-oregon
To clear any codes related to the srs system you will have to hook up the code scanner. Unfortunately I think that is the next step.
