Universal Hi-Lift Jack Mounts?
Hello everyone,
Does anyone have a source for a hi-lift jack mount that would fit on most roof racks. I have a voyager rack, but they only have mounts that are welded on during production. Any ideas?
Regards, David
PALR4
I googled and found a number of different companies offering hi lift mounts, but most of the rack companies don't have a side rail that is as tall as the Voyager. Most seem to clamp around the bottom rail and the top rail, so you would have to call the companies to find the specs. Here is a site with a bunch of different racks, and you could go to the individual websites and call them directly, as they don't seem to provide actual specs, because they are made specifically for their racks.
http://www.4wheelparts.com/Exterior-Parts-Car-Care/Roof-Rack.aspx?t_c=3&t_s=82&t_pt=3426
Disco Mike
Do you have front and rear aftermarket metal bumpers, if not the high lift won't work with stock bumpers.
Disco Mike
I have not seen anyone do it but I am going to say no because you won't be able to get close enough to the body to allow the Hi Lift a good hold, I know I can't with my full size sliders, only intended for metal, aftermarket bumpers only.
ougrad1
Uh, according to voyager offroad site for their rock sliders and their product photo, you can...
http://voyagerracks.com/lr3_lr4_rock_sliders.htm
CaptainSpalding
Explorer
Can I use the rock slider/steps as jacking points?
I have not seen anyone do it but I am going to say no because you won't be able to get close enough to the body to allow the Hi Lift a good hold . . .
I checked out the product photo, and it shows a Hi-Lift used on a slider with a step. I'm thinking that if you have the version without the step, you are totally out of luck.
About Hi-Lift jacks:
They can be extremely dangerous. They are best used with some training and practice. At minimum, get the Bill Burke recovery DVD. Hands-on training would be better.
The most obvious issue is getting smacked in the face with the handle as you lower the vehicle and the handle slips out of your hands. Good way to loose some teeth.
Another less obvious hazard— You get stuck in mud or snow or on some loose dirt. You pull out the Hi-Lift and start jacking up the truck. If you are jacking up from the side, as the vehicle is lifted it will want to move sideways away from the jack. If it does, even a little, it will change the angle of the jack relative to the truck. When you lower the truck, the upright member of the jack will make contact with the door, scratching or denting it. It happens often enough that you will read advice to raise the window glass before using the jack so that if the door is crushed at least you don't break the window inside the door. The worst part of it is that once the vehicle slips sideways, there's nothing you can do about it. Your only choice is to lower the vehicle and watch the bodywork take a beating.
There is an accessory that allows one to lift the truck with a Hi-Lift jack from the wheel itself. It helps to get the jack away from the bodywork. It's called a Lift Mate. It is good for getting un-stuck, but no good for changing a tire.
Perhaps a better option for the LR4 is an exhaust jack. They are sold under the brand names of X-Jack and Titan. Perhaps other names too.
Thanks, everyone!
CaptainSpalding, as usual, you are awesome! I do have the Voyager slides with steps, so that's why I thought they could be used as a jacking point. I don't plan to use the Hi-Lift jack until I've received some training on it's use. For most purposes, I have a great bottle jack that I carry that is safe and works perfectly. With that said, I would like to learn to us the Hi-Lift jack safely and want to find a home for it on my roof rack. Not to mention it looks cool hanging out there! :) Haha!
Any ideas on ways to attach it?
-David
DoornbosH
