Parts quiz – can someone tell me what that is??! Please!
rostov
VA
While changing rear brakes, noticed this some kind of bracket on the right hand side, and it was loose. Any idea what that is? And if someone could check if you have it there I would really appreciate it.
Thanks!!
BznLR4
It is a vibration damping weight (to damp frame harmonic vibrations). There is one on each side, although they are different sizes.
rostov
VA
Thanks BznLR4, but I am not sure we are talking about the same thing, sorry, I should specify it better - that is a small bracket that is hanging there attached to the body frame mount support by those 2 silver bolts.
I found it on one side only, it was loose. And I could not think of anything it could be there for. Some kind of transportation ties down bracket maybe?
NASdiesel
Went out and looked at mine. I don't have those two bolts/bracket attached. Just the flange welded to the frame. Do you have one on both sides or just one, as the flange is on both sides?
rostov
VA
Thanks for looking!! Yes, flange on both sides, but that bracket is only on the right hand side, very loose. I took it off. I have a feeling that is a transport bracket that was not removed, but... it took me 24K to notice it. :) I remember i heard some noise from that area that I could not determine what that was. I guess that was it! :)
Thanks again!
I will probably send this pic to my service adviser...
BznLR4
Indeed I misunderstood what you were asking about.
In 2011 LR4 I also have the metal tabs welded to the frame, but nothing attached to them (no bracket). Seems you can safely discard the bracket.
Meanwhile, tt would be interesting to know what those metal tabs on the frame are for! (anyone...anyone...?)
rostov
VA
Thanks for checking!
I thought that metal tab is a part of a robber mount support that is places between frame and the body... but not so sure anymore, I will check tomorrow...
Regarding the mystery bracket - it even has a part number, 14 11 60 RH.
Would be interesting to know how did it get there. :)
tango90
