How to change the battery in LR4 key fob
vegastim
Anyone instruct me how to change the battery on LR4 key fob. I've looked on youtube, but only found videos for Range rover key fob. Thank you
AxelR
It is indeed described in the manual.
Press the top little black release button on the top side (opposite to the key ring).
At the same time pull on the metal side with key ring attached to it. Battery tray is in there.
Count Laszlo
No, I have not. But I will now. thank you for the reply. :smile:
It's far more fun to ask for help on the forum and build some bonding relationships than look through some boring handbook like a worm. :creep:
asadmansoory
Land Rover Flip key Battrey
Land Rover Flip Key has rechargeable sealed battery and its Flip Key is permanently sealed by its manufacturer. If you can arrange its replacement shell then you can break open its key to change its battery and then use new replacement shell / body to refit that key again.
Here is Video for this process:
https://www.youtube.com/watch?v=RM6SzJ3e4uE
Well done DIY video. There is nothing quite like 10-15 minutes of royalty-free muzak... :wink: Too bad the LR4 doesn't use that type of key fob. You should post this in the LR3 forum, as many owners need to cross that bridge, either their case is worn or that rechargeable battery is no longer charging after so many years (you can buy and solder a new one on the PCB while you are replacing the case, as shown.)
ivan gonzalez
How does the battery recharge? Movement? Love? I got two and only use one of them. Should I start alternating them?
Induction. The battery in the LR4 fob is not rechargeable though (but far, far easier to replace when it dies.)
franklin
yes-this is what I have heard as well-much better than the older flip key style that was on my LR3-where it was very difficult to replace without going to the dealer for a re-program.
Disco2TrailEdit4
