Can I Disable Tire Pressure Warning Light Somehow?
Trynian
The check engine light can come on for any number of reasons once a computer threshold is reached - one of the most common but not the only reason is the loose/faulty gas cap. That's why you need the fault codes....
Tue but since he mentioned the reoccurring gas cap warning followed by engine light means it is most likely the evap system or the cap. He will read the codes and it will say one of 2 things either a massive leak or minor leak in the tank pressure which shows up as gas cap fault.
The list of items that can cause those faults are is fairly extensive:
Gas Cap,
Leak in the tank or filer hose.
DMTL pump
Charcoal canister ETC ETC ETC
The last three times this has happened in out LR club it was the DMTL pump.
how much is an IIDTool? I can't find pricing and well, to be honest not sure I want to be jacking around with my electronics too much. I was hoping it would be like the hood sensor fix with the paperclip and foil :)
About $400 from Lucky8 (there may be other dealers offering the tool as well.) http://www.lucky8llc.com/Products.aspx?ProductID=7738
IIDTool will also be able to read and clear the stored fault code that caused your CEL to turn on, it may help in pinpointing the culprit. It's got a ton of other useful features, such as the ability to reset the Service Interval Indicator on your own (can't do that without diagnostics on a MY06), to change your suspensions' height and store up to 3 separate height settings, etc.
Sonies
yeah but my engine light went off...:confused: so not worrying about it anymore lol
and my tank isn't leaking anything... its just the BS sensor acting up, everything is fine i've checked a million times, no leakage
Trynian
Many times it is the valve on the DMTL pump sticking and not closing all the way when it does the pressure test that causes the error.
LR13
My check all tyre pressure message keeps coming on and the low pressure warning light goes off and on. I checked all pressures and they are good. What to do on my LR3
Waterski
Does anyone know of a place in Alberta that can disable the TPMS (reconfigure the system)?
wyrover
Our 07' was doing the same thing. The dealer said it was a failing TPMS module that was on it's way out. I used my IIDtool to disable the system.
roverman
Interesting, I specifically asked one of the vendors about disabling the TPMS and they said you can't do it. Maybe they just aren't allowed to say you can?
For anyone who would rather fix it, the modules in the fender liner are easy to access and simple to replace.
