IPod question
AceRider
DFW, TX
As long as you don't try doing both things at the same time... :biggrin: Connecting an iDevice to the dedicated USB port (for playing or charging) will disable Bluetooth audio streaming.
So, does that mean if you get a phone call (which as far as I know is Bluetooth transmitted) while playing an Ipod or other device, that it won't disable the music and switch to the phone?
Or are you only saying that you can't stream MUSIC while another device is plugged into the port, which sort of makes sense to me. Kinda.
epiclr4
No what he is saying is if you have 1 iPhone connected to the system through Bluetooth and Bluetooth only it will stream music and make phone calls.
If you then plug that phone into the USB port it will no long stream music through Bluetooth as it will then play music through the USB port. It will then only do phone calls over Bluetooth.
Surfrider77
FWIW for any audiophiles out there: You want to use Bluetooth audio streaming as a last resort anyway. The compression over BT really kills the audio quality (even moreso than iPod m4a / AAC). This isnt a LR specific issue, but its a BT issue in general.
PE_in_UAE
