tranny shifting rough
simjet22
good day folks! a day ago i got a check engine light pop up on and reduced performance in the display. I shut it off and restarted it, and the check engine went away and never returned. so i had it check out by my local mechanic "with LR experience". he scanned the truck and came up with a code for one of the cam sensors going bad. i have an appt. with LR to get it repaired this week. i know he cleared the code and since that my tranny had been shifting hard and i really feel the downshifts now. also the truck had a lag when i step on it, its not responsive as it was before. does the transmission needs reprogramming?
Surfrider77
It's possible it could have reset the transmission computer and it needs to "re-learn" your driving habits again. This is common with quite a few automatic vehicles. If it persists for a long period of time, get it checked out.
simjet22
Thanks for the reply. Typically, how long is the "re-learn" period?
LR4USN
How can you force it to learn again ?
LR4USN
Thanks good to know UM
simjet22
You need to reset transmission "adaptions" via diagnostics (a battery reset won't do it.)
Thanks for your help, im new to the forum. Now my next question is what's the best diagnostic tool to buy for this vehicle?
Search the forum for "IIDTool". That's by no means the only aftermarket diagnostic tool available to the Land Rover enthusiast, but it is relatively inexpensive, very compact and cleverly easy to use. Among its many other features it can, of course, reset engine and transmission adaptions.
simjet22
awesome! will do
Surfrider77
And best of all, IIDTool can override your EAS (Electronic Air Suspension) to give lift at any vehicle speed while offroading.
Highly recommend this device! +1
