20" RR Wheels on a LR4?
coltranes
Guys-
I am looking at purchasing a new LR4 w/ 19" factory wheels. That said, I would like a second set of 20" wheels for summer months.
eBay appears to be loaded with 20" take offs from RR and Range Rover Sports. This is an example. http://www.ebay.com/itm/2013-LAND-R..._Car_Truck_Wheels&hash=item23473b706b&vxp=mtr
Will these wheels (20x8.5) fit an LR4? These appear to be identical to an optional wheel that can be configured via LANDROVERUSA.COM
Thanks in advance.
epiclr4
Guys-
Thanks in advance.
Search will go far as someone else just asked this question about 3 weeks ago.......
But yes, RR and RRS wheels will fit the LR4. The wider RRS wheels should fit with no issues but if you are going to run oversized tires you might have to watch for lock to lock issues almost like any other oversized tire issues.
EDIT: Yup, 3 weeks ago..... Page 2..... http://www.landroverworld.org/forums/showthread.php?t=26717
jjvd21
Check the weight ratings of the wheels are the same or higher than OE for LR3 and LR4
MCieplinski
I have 5 19in with cooper LTZ tires on them (80%thread left). Let me know if you are interested
NASdiesel
Depends on which RR wheels, but I run some 20" RR wheels. Check the backspacing, I think some were more than others but not 100%.
Even though 20's are sort of silly on the lr3/4, I had the same ones you've got and they always look so darn cool ;)
What tires do you have on them? They look like they fit quite well.
Also, I don't recall exactly but aren't those 20" wheels 8.5 or 9" wide? I feel like when I had mine with 285/50 Toyo Proxes they fit great but just barely at the upper A arm partially due to where the rim sat and it's width.
