Mudflaps from Hong Kong
Davidinseattle
admx
Well, there are brackets, but since there were no directions, I didn't use them. Wonder what they are for?
Here are some pics. The car is really dirty, but you get an idea of how they fit. The fronts went on really easy and the fit was pretty good. No issues other than having to push up on the flaps to get the holes to line up, which I assume is on purpose to get the tight fit.
Now for the back. I just couldn't get them to fit tight where they met the lower trim piece (molded plastic one). Maybe that is what the bracket is for...I guess i should have googled it. When I forced it tight, the fit was perfect, so I used a stainless steel medium thread screw to pin it tight. I drove the screw through the trim piece but from the outside. You can't see the screw head as it is buried inside behind the finished outside that's visible.
Once I pinned it, the contour tightened up and fit very nicely. I did not have to trim either the fronts or the backs. I didn't have stainless bolt/washer/nuts which is why I used the SS screw. When I get to the hardware store, I'll pick up them up and replace the screws with something more permanent.
These flaps are pretty flexible. I don't think they'd snap. When putting a screw in the rears, I bent them out to get in there and they were fine. For under $50, I'm happy. The same from JLR is over $200. Now if I can just figure out what they heck those brackets are for?
jettore
Have a photo further back of them? Maybe the entire side to see how they look. Thanks
Davidinseattle
Here are some better photos of the Hong Kong Mud flaps. They look pretty normal to me. Don't really even notice them on the rig.
Here's how they look on mine. Exactly what David said, "No Instructions." But they are simple to put on.
Georgemera1
Can you let me know what tires size are you using in you car. Let me know please.
Thanks in advance.
jpjp
Florida
They look like 255 55 19's
I'm taking my flaps off this weekend, actually ripped one off at the gas station on the way home from a Florida Land Rover Club rally last weekend. The rally was at Osceola National Forest on the Fl-GA border. Very wet so didn't get to wheel to much there. On the way home stopped at Hard Rock ORV park north of Orlando to get a few hours of elevation, which doesn't come easy in FL.
