TMPS Recommendation ?
hatch
Pennsylvania
Okay, so here's the story after a conversation with TuffAnt -- and I'm guessing the same applies to the Terrafirma.
The steel construction leaves less room on the interior of the wheel barrel. So, while the OEM and similar TPMS sensors can be mounted in the valve hole, there is not enough resulting clearance to do anything with them once they're mounted. A TPMS sensor with a rubber valve stem (not the OEM sensors) can mount on the steelies and be useful, but those with fixed/unbendable valve stems cannot.
It appears as though there are VDO TPMS sensors with rubber valve stems @ 315mhz that supposedly work with the LR4 models which use this frequency. There aren't sensors at 433mhz made by VDO or other manufacturers that offering auto-program that come with a rubber valve stem. There appear to be some other brands making "universal" 433mhz sensors with rubber stems, but whether they'll play nicely with the LR4 and/or whether they need a GAP Tool or the like to get them setup, I can't say.
The alternative to finding a rubber valve stem, compatible sensor and sorting out the setup/programming issues is mounting the entire valve and sensor assembly on the center of the wheel using TPMS bands/straps. With good tape and a proper install, this supposedly should work just fine.
For my part -- I've decided just to ditch the LR4 TPMS system. Given the cost to buy new sensors that might play well with LR4 or might not (anywhere from $140 to $250) and the cost/hassle of finding out whether they work (have to be fully mounted and drive over a certain speed before most sensors can be read ... meaning if it doesn't work, tires have to be pulled off) and, most importantly, the fact that the LR4 TPMS system is unintelligent/of limited use to begin with (no pressure reading, just PRESSURE BAD), it all seems like a big effort for little reward. I suppose I could strap mount them, but the same issues with testing/umounting exist and I've read plenty of feedback from users who had strap-mounted sensors of this sort come unstuck and start spinning on the barrel. And all this for what? Unintelligent sensors?
So my plan is to go with the much more intelligent valve-cap sensors mentioned earlier in this thread and find a way to disable my TPMS on the dash. Hopefully I can find some other way besides buying a GAP tool.
LR4s went from 315MHz to 433MHz in 2013.
Troy A
San Francisco, CA
Great info above!
I have had good success with the Tymate but they are a rather cheap Chinese product with the usual poorly written instructions that you have to interpret.
ARB has equivalents and there are MANY others on Amazon.
Honestly I see so little value in the LR TPMS in terms of cost, complexity, and after-market wheel fit, I think it's easier to turn off the built-in TPMS functions.
Curious why you don't have a Gap IIDTool. Man I love mine.
Gravey
Phoenix
I did not. Hopefully he'll weigh in. Thanks for the heads up.
I took them off and will remove warning once I buy gap tool (waiting for black Friday). I didn't really want to spend the money for new ones. I was told they can't be mounted in stem. In could mount with band. I assumed the Tpms sensors were original and near end of life. For me, they don't seem worth the money especially when I plan to air down and up frequently.
Socialseb83
Houston
I've been using the TyMate external TPMS sensors. They're external so you can just move them around when you rotate the tires. And they give you both tire pressure and tire temps and you can set alarms for high/low/temp conditions.
https://www.amazon.com/Tymate-Wireless-Monitoring-Real-time-Temperature/dp/B07HNPQ4X3
I ended up with two sets at one point which was good because I drove off without putting a sensor on last week so I was able to grab one of my spares, put the gauge in learning mode, and reset it all so they would all read fine.
I also run the LR internal TPMS so they're both active simultaneously. I have often wondered about your question - whether anybody had found a way to get data from the LR TPMS and display it on the dash or on a phone.
In the absence of an answer to that, I just went external again (which is what I've done on my last three vehicles.)
I’m definitely ignorant here. Here is what my noob self assumed: the LR computer told you if TP was low and that was that. This post is making me realize there’s waaaaaaaaay more to it than that! So i need additional sensors on each of my tires? This gives me reading homework for the weekend :/
