Persistent P0430 on my 2012 5.0
M32H32IS
Texas
2012 LR4 190k miles, 40k on reman engine.
Recently developed P0430 code. Ran 2 cans of Cataclean and still comes back after I clear it with my GAP.
What diagnostics can I do (GAP Gen 1 no BT) to figure out if I need a new cat?
scapistron
Massachusetts
You can try new O2 sensors on the relevant bank. Should probably replace them with the new cat anyhow. Toss 3 new sensors in and if it goes away, win. If not swap them over to the new cat.
powershift
Nevada
Could you try moving the sensor on the other side to the problem side and see if you still get the code? On a different topic, I'm curious about your original engine. How did it fail?
M32H32IS
Texas
Crossover busted doing 80 on the interstate (prior owner) by the time he was able to pull off the road the engine was cooked.
Rover Range
Texas
A bad sensor won't cause that DTC.
Convertor needs to be replaced.
Or, get one of these. They do work.
COL Brown
Fort Moore, GA
Replace your air filters and make sure there are no leaks in the air filter duct work. I went down a rabbit hole after getting the same codes. I replaced the spark plugs, put in cat clean and fuel injector cleaner etc. It turns out the air filters were dirty and too restrictive. I replaced them and the problem was solved.
scapistron
Massachusetts
Would he need three of those? Or only one in the last position?
M32H32IS
Texas
I’m giving those a shot as I don’t believe the cat is faulty. I’ll replace it next month if need be.
I know I’ve got an exhaust leak on that side. Bank 2.
16RRSportjyn
