expedio2005
Ok, I admit I was freaking out a bit after getting home from my drive last weekend and lots of possibilities were going through my head so I was spitballing. I checked a 4th time today that the belts were routed correctly, and they are. I did not have a light (it was dark out) when looking at the coolant reservoir after getting home and having my vehicle die in my driveway thus I couldn't properly see the color of the coolant in the tank. The pink coolant (LR4 specific) that I bought apparently isn't as vibrant when viewing through the semi-transparent white plastic reservoir. Dunno what the rattling was but sounded like dice being shaken in a plastic cup. As stated in my original post, there were no engine related codes. I have a known code for a faulty door lock and rear passenger video screen. The other new electronic related codes I had have gone away since I bought a new battery.Too many things going on here.
Firstly, “routed the belt correctly”??
Secondly, “rattling noise”??
Thirdly, “black coolant”, “down 2 qts”??
Fourthly, if there is oil in the coolant, what’s in the oil?
Fifth, “battery low”.
Lastly, where are the codes?
I’ll say it; Perhaps you took on more than you should have.
But this would be the order I would have it looked at.
