Rear Tire Carrier - Any Regrets in Daily Life?
bdd123
USA
I have as of yet gone forward with getting one, though it would have been handy recently as I picked up multiple screws a couple weeks back and ruined one of my fairly new KO2s. It was replaced under warranty but I had to fish out my spare and I was immediately regretting NOT having the carrier! So it goes.
That being said, the more I research the matter, the more it seems like waiting to do something like the T44 setup makes more sense. The added plus is they're actually fairly local to me if/when the time comes.
So presently I'm of the mind that if I can do it in the future I will be going straight to the T44 solution for functional purposes over pure aesthetics. I don't see myself excepting a 32-33" tire ever on this truck (31.5" right now with the KO2) so major oversized tires and subsequent modifications will not be in the cards.
Well. I am ready to buy. Emailed Tactical 4x4 and they dont respond. Last time I emailed it too a couple of attempts and days to ask questions.
Have they told you lead time?
I dont know of a size in inches for a land rover wheels most are width, aspect ratio, radius.
powershift
Nevada
I stuffed my spare tire pretty badly and it isn't fool proof underneath like I thought lol. I had it in off-road height and Sand mode well before this section in the center bottom of the pic. Turned off Sand mode to Normal, waited for the mode change confirm message in the DIC, then stared at the off-road height icon reflecting UP position. Stared at it even longer, then even more. It never changed position so I start driving and forget all about the f Sand mode to Normal mode drops the suspension later?
Not sure but you can see the spare tire ring in the dirt when it hit and bottomed out in the rear. It stopped the truck even though it wasn't going that fast lol Thinking about it in hindsight, the automatic suspension raise mechanism didn't fire. Maybe that is only for the front to raise up if it detects high centering?
I was thinking about putting a water tank underneath where the spare tire is now and then retrofit a battle bumper with nato water and fuel can mounts lined up across the width. The water tank would need to be pretty beefy if I make another mistake like that. The spare came loose and bobbled around. It will go through the washout fine in off-road height.
Land Rover Joe
Oxford
@powershift
That (back end "snow angel" in the dirt) has happened to me too - only in deep sand (so no risk of breaking anything down there in the wheel well). My fault (as usual): I basically dug myself into the sand.
So you bring up a couple good points and advocacy for the "rear tire carrier" debate.
First, the tire can get banged up down there...but they seem to do alright (I don't personally know of anyone who has wrecked a spare). That said, the stupid gear/wheel winch assembly CAN break and HAS broken on me (NOT my fault this time...some dumb person used a drill drive and striped it when changing the tire). That makes that part useless if you do strip it.
Second, there is a very excellent argument (which I support in concept) to be made in order to use the under-body space for something else (like water or fuel). That would be the best place to put heavy stuff given the center-of-gravity for the truck. However, I do not personally know of someone doing water tanks there (great idea though!) and have only read of one person with an LR4 who put a secondary fuel tank there (which was apparently really complicated since it was for a diesel DISCO3 in AUS).
Finally, for those who think putting a spare tire on the roof (rack) is a good idea: I disagree. I have done this myself and my conclusion is that it is the least preferable option. If ever, I would recommend putting just a tire (carcass) up there. To begin, a full sized wheel and tire is a lot of weight up that high. This puts a lot of weight on your roof rails (too much) and again messes with your CoG. Then, if that thing gets loose - you have a really heavy identified flying object...which cannot possibly end well. And for the last thought on that...getting it up there and then getting it back down really sucks (and is a little bit dangerous) and is a two-man only job (unless you throw the thing off...which I would also not recommend). Whenever I was taking the wheel off of the LR4 (with all the glass everywhere), I had visions of me dropping it and shattering a window. Over time, those visions cured me of that idea (to put big, heavy things up there and contributed to me getting the heavy duty bumper with carrier).
All of those instances are good reasons why to use the carrier in addition to not having to pull all of the junk out of the back - photo of me changing out a tire I shredded (driving too fast) in Africa (years ago) below. This was a long-distance, off-road trip and so the back was full...meaning what you can't see in this photo (next-to the passenger side rear wheel) off in the ditch on the left is all the junk I had to pull out of the back in order to get the spare wheel down. So I know and am well versed in that particular need!
But in the end, the steel bumper just looks the coolest.
Still no regrets for me getting the bumper. You get used to using the swing arm (but my wife refuses and still detests it). It is really not that big of a deal (and even better for those folks who dismount it).
Land Rover Joe
Oxford
For Point Two:
Reach out to @avslash on this forum (who I referred to) -
I guess there are a couple folks with that modification.
Some options -
https://www.browndavis.com.au/products.php?make=LAND+ROVER&model=DISCOVERY&series=SERIES+4+2009-2016 (the tank @avslash is referring to)
https://longrangeamerica.com/shop
Also, a newer product I wasn't aware of -
powershift
Nevada
When I bottomed out on the spare it pulled the tire a bit loose. I wouldn't trust just the winch It really is a POS. I need to replace mine yet again, 3rd time.
m_lars
Utah
A few random thought replying to previous posts here…
In my view it’s well worth the hassle. In the summer time I have the added step of my upright bike carrier having to be tilted out of the way, then the tire carrier, then the upper gate and finally the lower gate. Giant pain if I forgot to throw something in my drawers and my only option is to open back up! But I wouldn’t got back.
I have an LR3 and run a carrier of my own making, my the latch is less convenient than the commercially available units, but still worth the effort.
You can run 32-33” tires without any mods IF you go skinny, rather than wide. Once you start getting close to the max height, width becomes your fitment issue. I run 265/70r18 Cooper S/T MAXX, have no rubbing and have the frame horns inside the front wheel well intact. I ran a 5 tire rotation on my first set and got 75k out of them. There’s no way the spare would fit below and if it would it would have been damaged without a doubt given the scars I’ve got on the underside. Before my carrier I ran it in the roof (HATED getting it up and down) or in the back and lost cargo space. I even ran without a spare when I was on roads only and wouldn’t you know that’s when I got my last flat!
If you have the option with a new off-road part, get it bare and have it primed and painted locally. Powder coat sucks for this application, it’s too hard. As previously mentioned, it rusts from the inside out. When it does get damaged, you can’t fix it. If you prime and paint, you have the option of sanding, priming and painting it again. There was a brief time when light aircraft guys were powder coating their airframes, only to find out the tubing could completely rust away and not be able to see it on the outside.
tragic1
