MNFish
Hi all! New to the forum. Just bought a 2008 RR lr4 4.4 non supercharged. Has 183k miles. Im a diy mechanic. I have a couple questions and will post each separately
Looking for a scan tool to use to check and clear engine codes and calibrate the suspension. I’m getting “fuel cap loose” on the dash readout. Guessing since it’s a newer fuel cap that I need to check vacuum? But would like to be able to see how the rest of the system is operating. In relation to the scan tool again I replaced the front drivers side airbag and I wanted to calibrate the suspension. A couple fender wells seem to be an inch higher than the others. And access height seems high but then I can only compare it to an o8 Jeep grand Cherokee I used to own so maybe it’s correct but want to check it anyway
