2013 LR4 headlight lenses on eBay
RoverMike
Any recommendations on what lens to get on eBay, mine have gone dull and found some replacement ones on eBay?
16FujiDisco
Nashville, TN
None, but I’m interested in your results. I’ve been putting off replacing mine, but I want to try it.
The oven process makes me nervous, but I’m going to have to just knock it out at some point. If yours could report back with any tips it would give me some confidence; all the vids online are RRS lense replacement, which I know the process is the same, I just like to see an exact example.
RoverMike
Im also a little nervous on sticking them in the oven, but I definitely gonna have to do it, mine are just awful at this point, but ill definitely post on here once I do it
Rubber Cow
I used the following kit from amazon on my '12 LR4...worked great if you take the time to mask off the edges - work was done in less than 30 min for both lenses.
3M Headlight Lens Restoration System, 39008​
Available on Amazon
MellonRover
Northeast USA
I've used the Sylvania kits on multiple vehicles. Lr4 are one of the easiest because of how easy ( if the clips slide) they are the remove. Sylvania kit has lifetime warranty and the uv blocking top coat won't yellow.
DylanM
Don't waste your money and time on the auto parts store headlight kits. Useless.
Most are...
Agreed. The Sylvania kit is the only one that will get pro-level results with a little modification. After the initial sanding steps, a final machine polish with a polishing compound (e.g. KochChemie Fine Cut) will clarify any micro scratches down to 2500 grit - this should get you perfect clarity before the final UV coat. Would also suggest a ceramic UV coating (like Dr Beazleys Headlight Coating) after a week or two of curing.
Here's how mine turned out...
powershift
Nevada
I've been applying UV protection to mine as well as waxing them. They are scratched and I think it might be from bush? Only the drivers side is scratched at the top corner but not the paint.
MellonRover
Northeast USA
