Routing for stout wires from battery to back?
Land Rover Joe
Oxford
I'd assume there's knockouts in the firewall for the RHD version.
Question for @scapistron : Are we talking about a RHD (i.e. UK) or LHD (i.e. NAS / LR4)? I am only going to speak for the LR4, which is what I am driving. RHD would be a rather different animal (because a UK variant would both RHD as well as the Discovery 4 TDI V6 engine)....
Land Rover Joe
Oxford
Errr….i don’t suppose anybody knows a pass-through in the firewall on the passenger side?
Regarding where to push wires through the firewall on the passenger side (so again – I am referring to a NAS LR4 / LHD): you can make a cut in the large rubber grommet / seal which services the large wiring loom going to large series of panels behind the glove-box.
Several photos of mine are attached here for your reference (as with everything ripped out right now it is relatively easy to see): look at the lonely white wire, which is the control/lead wire for my TRAXIDE unit that feeds into the control unit stashed away in my glove-box (one photo of the *****/cover less unit in the glove-box attached. This photograph is from the front of the engine looking toward the rear of the vehicle with the main ECU / computer to the right and the edge of the engine bay (corner) to the left.
TRAXIDE (i.e. Tim at @drivesafe) has the installation instructions for this unit which comes with a host of photographs so you can reach out to him if you are interested in one of their products.
Note – I like TRAXIDE’s work but am not getting any kickbacks! In fact, I am considering removing my TRAXIDE unit right now (this is the USI-160 power controller for the auxiliary battery install) and just replacing it with a generic battery isolator (if so, I am going to leave the control wire in place in the event that I would need to wire up something else into the engine bay someday.
Hope that helps!
drivesafe
Hi LR Joe, just note, ordinary isolators will not work with your SMART alternator operation.
You will find that if you replace the Traxide unit and you use a fair bit of the auxiliary battery's capacity, you can only use a DC/DC device to get the auxiliary battery properly charged.
Land Rover Joe
Oxford
Thanks!
Bumping this thread. I’m looking to route a wire for power all the way to the back. What route did you end up taking? I don't have a preference on driver or passenger side.
greiswig
SW Washington
I ended up going through the firewall on the passenger side. I made a hole, and put seals on it.
