03 Freelander won't start today!
beteacher2002
Good morning!
We are looking for some technical expertise as to thoughts why our 03 Freelander is not starting this morning! It ran fine yesterday.
When you turn the ignition switch, it sounds like it wants to start (turns over), but it won't start. Could this be a fuel filter problem? The other day when we were driving and stopped at a red light it started sputtering, but when given gas it functioned normal.
If it is a FF - where is the part located in the vehicle?
Could it be an oxygen sensor?
We are looking for any advise all of you experts can give... thank you very much!
joey
Without knowing info like mileage and when the last tune up was done.... it is hard to say.
I would check to make sure you have fuel, check the plugs, wires.
E
ecmoney
Guest
Good morning!
I had the same problem a few weeks ago, my fuel filter just went as I couldnt start my car. It was turning over and starting but would die seconds later as no fuel was getting through. Cost about $450 for a new fuel filter up here in Toronto. That is for the part alone, no labour.
