tucker
tucker
Hi this is my first attempt to this forum. I have a 1999 range rover 4.6 Westminster lhd. I have two problems I hope. My air suspension is working ok but my warning light is on the dash and my suspension indicator switch has all 4 lights illuminated at all times.
My second problem is I light vibrations through the full motor when driving. This is not the case when vehicle is stationary and even with the engine is running at high revs. I have had all wheel bearings checked and the exhaust checked it’s not rubbing on the vehicles body.
I am living in Bulgaria and unfortunately they don’t seam to have much idea in diagnosing problems. They have the equipment but don’t know how to use it. I need help.
joey
Welcome to the forum..
As far as the suspension lights without being able to put it on the LR computer it will be hard to say.
Vibrations, could be a U-joint in the drive shaft, or a bad/bent rim or a bad tire.
tucker
joey
thanks just had all new tyres fitted will get u-joint checked and get back.
PE_in_UAE
