repair/service manuals
Im looking for manuals,dont know where to find them. Im doing brake rotors and need a little guidance because im not 100% familier with disco brake systems. Please help.:confused:
joey
What year disco?
joey
Brakes are simple, rotors a PITA....
PM'g info on manual.
Thank you very much. Idk how hard it is Id rather do it myself and save $.That and I learn about my disco.
issacd
eBay
I purchased an inexpensive CD-ROM based service manual on eBay ($5 or so.) It contains the original factory service manual and the owners manual. It seems to get the job done. The Disk requires a PC computer running Windows. I tested it with XP and Windows 7, both work fine.
Also if you are looking for paper service manuals, I would look at Bently brand.
Disco Mike
You can also down load a free Rave CD, complete shop manual, use the link in my signature.
Make sure you read up and do a complete front service to your swivels, bearings and brakes, it is really important on D1's.
deeb
hey man,
just so you know, i just got a disco 1 and the first thing i did to it was replaced the rotors/pads...piece of cake, but plan on a full day!
the walkthrough in the repair manual is quite sufficient.
before you get started make sure you have one of these guys...
http://www.roverparts.com/Parts/606435.cfm
also get a tub of bearing lube and clean up your bearings and repack them.
if your pads and calipers look like mine, i would pull/replace the pads while the calipers are out.
good luck!
chad
