Oxygen sensors
dandyrover
Are there any instructions on how to replace the oxygen sensors on my 2000 Disco II?
Disco Mike
Why are you replacing them, are you having a problem, have any fault codes, what are they.
02's are plug and play, make sure you get the right ones, none of the generic that you have to wire the plug to.
dandyrover
Getting about 7-9 mpg and have codes that indicate both front and back are bad. 88,500 miles and finding that very little maintenance has been done on it. As far as the O2's, how tight should they be tightened? should there be anything put on the threads for a tight seal?
fathandracin
Check summit racing.That was the cheapest place that had them for mine.
Benny1
Hey I'm havin huge 02 sensor problems and is there a different sensor for before cat and after? was told there were 4 sensors and the idiot that owned it before me took them all out and put bolts in the holes. Running real rich when it runs at all any suggestions?
Benny1
this is a 96 disco and I need to find the cheapest way to fix this rich fuel and no sensor problem. what if I cant find the wires to attach to the sensors?
Benny1
if sensors are missing and you scan the computer for problems will it show all kinds of problems that dont really exist other than the four sensors I know are missing?
Benny1
missing 02 sensors
Hey mike just found this site and wondering if you might have any advice for me regarding these 02 sensors? The guy that sold it to me took out all four of the sensors and replaced them with 3 inch bolts I cant find the wiring to hook the sensors up to if I did buy new ones to replace them with and this truck barely runs. it runs real rich and dies constantly. we hooked it up to a hand scanner and it showed messed up sensors all over the vehicle and I'm wondering if the four missing sensors could cause this thing to show that there are more problems than there really are. Do you know any where to find these sensors cheap and also are there two different type of 02 sensors? Thank you for any advice you can offer.
Benny1
96 discoery sd
sorry to bother you again but I wanted to tell you its a 96 disco sd
greg409
They're similiar to spark plug threads, I don't think you'll get a torque wrench on them so just snug them
the new ones should have gaskets
Careful of crossthread
Put anti-seize on the new threads and not a lot, you don't want it on the sensor.
luck,greg
