2007 LR3 Bonnet Open didplay
ladysteelers
US
HELP Please help!! I had my truck in the shop for two weeks trying to figure out and correct the green flashing “transmission low” to no avail. It’s still a hit or miss as to it engaging... Now I’m plagued with the “Bonnet Open” message. It’s driving me insane not to mention I have come to the conclusion that this sensor is the culprit behind my inability to lock my car remotely. It is only seconds/minute and the alarm goes off!!! Am I correct and how do I fix this??? I have been fortunate with this forum when it comes help solve issues I just knew were going to be of huge expensive to be pleasantly surprised with some fixes being minimum charge to free!! I hope the streak continues
Easy fix is to remove the switch and hard wire it together. or Replace the switch and make sure it is working correctly. Transmission low means it is low on fluid, or your battery is going bad.
mray
My previous 08 LR3, bonnet open equaled new battery needed. However I never got the trans fluid low.
