Preventative maintenance recommendation for a 9 year old LR4 w/52k miles
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Yeah, don't ignore coolant or oil leaks like @D_Walt said. Most oil leaks are from hard brittle valve cover gaskets and at that point, you're halfway through getting to the timing chain guides. Just food for thought.
JotaDe
They thought it may be the brake vacuum pump, but after inspection that wasn’t leaking. Def keeping my eye on it.
D_Walt
Arlington, VA
So I was also told it might be the brake vacuum pump, but it wasn’t. Having that re sealed during this chain guide job because. To @djkaosone point, it’s a lot of the same labor if it is a timing cover or valve cover leak so if your on original chains and plan to keep it, maybe have that is a smart play. It would solve all the common oil leak spots, aside from the vacuum pump.
that’s why I decided to have my guides replaced.
JotaDe
I've had the vehicle back for 6 days and heard this noise last night. Started as what sounded like a small electric hum / whine that we could hear driving. After getting home and sitting idle it got really loud. At first I thought it was a belt, but it doesn't sound like the usual belt scream I know so not sure.
**Just started it up cold this morning and the issue wasn't occurring, looks to be something that happens after the engine is warmed up and has been running for a while.
JotaDe
Whelp, it was a PCV bleeder hose. $90 plastic hose sitting on top of the engine was cracked and sucking in air. Popped off the old one and installed the new one, no tools even required.
PE_in_UAE
