2016 LR4 Camera system not working at all!!
Rover Range
Texas
You may have a camera "pulling " down system.
Try connecting one camera at a time- start vehicle- and see if you can isolate the bad one.
greiswig
SW Washington
Update- I purchased a used camera module from eBay. Swapped it out and it immediately started working!! Couple days later, the thing dies again- same issue as before. Now, have I pooched 2 modules, or is there something else going on? Why did it work for a few days? Very frustrating for sure...
At this point, I’d be experimenting with plugging in the old module to see if it shows the same behavior.
JimmyY
Canada
Great advice, thanks ! Unfortunately no matter what combination I do the camera module will not function. New/old or any combination of cameras connected, even zero cameras connected, nothing ! Hard to believe something in the vehicle is crapping out these modules. I've been thinking of replacing the head unit with a more modern one- any chance it could be head unit related? Would suck to spend $1000 on a head unit and still doesn't work though.... Guess I should see what the dealer suspects.
Rover Range
Texas
Does the park aid switch flash on and off?
A bad park aid sensor can cause the cameras not to work.
JimmyY
Canada
It does not. Sensors seem to be functioning normally. I have a hitch bike rack and it beeps in reverse. Really missing the rear camera with the rack on in the summer!
Rover Range
Texas
With the ignition on, engine OFF, vehicle in reverse. Do the same in drive, to check the front sensors.
You will hear a faint clicking noise from each sensor.
JimmyY
Canada
Oh! So maybe it's been a failed sensor this whole time. How can I accomplish putting the car into drive/reverse without ignition on if my shifter won't come up? 2016- recessed shift knob. I think I will go around and clean all of them anyways. Thanks !!!
JimmyY
Canada
Each sensor appears to be functioning normally. Wife in the driver's seat and I cover each sensor and alarm goes off each time. Damn, I thought that could have been it!!
Sid1577
