1" lift spacers.. easy install?
Zende
Im in the process of purchasing some bf all-terrain tires for the 95 disco 255/70/16.. I also wanted to add some 1" lift spacers from atlantic british..
Are they a easy install? Anything special I should be prepared for?
Thank you
98GRDisco
I think it is rovers north that sales a 2" spacer for about $100. 00
Zende
What about the 1", no good?
Are they easy DIY install under the springs?
98GRDisco
I don't know about the 1" if they are easy to install or not but I know from the picture of the 2" blocks they look pretty easy to install and I plan to get the 2" block in mid to late May and install them I will let you know ow easy the 2" are to install may that will help you.
719jak
lift spacers
I have 1" raised springs with 2" spring spacers easy to fit spring compressor tool makes things easier but 2" and above will require longer shocks and change castor angles see www.lrautomotive.com.au:cool:
