1998 window problems
vtails
I have not been able to get the 2 rear windows to work, I pulled the switch panel and started looking for power,I found that it had very little vcc (.023) so I checked the fuss and it had 12vcc on both sides so I am thinking it has drop a grd. to the rear windows,I dont want to pull the console,but I will if its a must,, does anyone know where the grd wire is located for the rear windows,Thanks for any info.
Rear window ECU has a crack in the solder joints... behind the glove box.
Maddie
Ps: FYI doubt the trouble is a grounding issue because joey usually knows but the ecu ground is behind the right fooltwell cover if it is like my 95. Ground e200 also grounds the dang cruise ecu that I'm having trouble with.
vtails
When you say ECU are you talking about Electronic control unit that runs the engine trans and a few other things or is this a seperate control unit for the windows,Also sorry about getting back to the ? I just got back from a work I fly 3-5 days at a time,so last thing I want to see when I get to the hotel room is an other computer screen if you know what I mean.. I'll tear it apart tomorrow also I to am having problems with the cruise control but its just hose's,I read the treads on these two problems.So I'll get back to you an let all know what I found,Thank you
  • joey
PE_in_UAE
