2001 disco 2 not starting
terryjh6
does anyone know if the 2001 disco 2 uses a vats or pats key?? the key i have is an old steel key it will turn over the motor and it will unlock the shifter. but thats all, just wanted to know if it uses a chip in the key?? thanks Terry
No chip in the key that I am aware of... check the battery.
skarts
usually when you turn the ignition key you want it to start Try starting the vehical in neutral, sometime the saftey switch goes bad....
Land life
