2003 Disco Missfire/Brake/Many more Issues
Chemical Smitty
Okay... here are the issues I have:
Brakes: a year ago, I decided to replace the rear pads and rotors on my Disco. I was able to get the passenger side done, but nearly rounded off the caliper bolt on the driver's side. A month ago, after dealing with loud brakes, every light associated with the brakes came on (Brake, TC, the downhill one, ABS and I even get an intermitten SRS light). So I decided to chance rounding it off the rest of the way and attempt to change them. Using a wrench and hammer, I got it loose and changed the pads and rotor but the lights have not gone off (and I've noticed the ABS does not work). I live on a big hill, so I know the E-Brake works.
Hesitation/Missfire: Over the past two years, I have had the Disco in the shop 3 times for missfires. First time it was a coil. Second time it was plugs. Third time it was the CAT. After picking it up the third time (LR Nashville had it for a month) it still missifres when I start it after it has sat for more than 24 hours. It has 1 y/o 7mm Magnacores, a brand new battery, and at least 4 of the plugs have been replaced (I'd have to pull them all to check which ones the dealer replaced).
Radio: No matter how loud I turn it up, I can't hear any more than faint noise.
Front Passenger Window: Will only move slightly (on one side) and if you press in the opposite direction, returns to the original spot.
Where do I begin?
My thoughts are: Switch to Bosch Plugs, Sea Foam (if fouling is the issue), and from there I am lost.
It has 78449 miles on it.
I can get the codes, although I'm sure there are many and I may have to have them cleared, drive it for a bit, and have them read again.
If you want to PM me your number, I'll work you thru all these issues. In the mean time, quit throwing parts at it that don't fix what should be a simple repair.
