2006 LR3 Fuel Sending Units
troysmith80
Bend, Oregon, USA
matthew, thank you so much for documenting this and with pictures! I can only imagine how frustrated you must have been! I certainly hope to benefit from your efforts. I lost my fuel level recently and will definitely check that harness before dropping the tank and dealing with all that!
remember5
Just saw this comment and need to mention the relay was the culprit for the intermittent start in case that helps anyone. All is good now.
remember5
Yes. I don't remember which one but it was in the main relay box by the battery.
KenG
Huntsville AL
I'm finding Matthewwrn's post very useful (even though I haven't solved my "fuel gauge says empty" on my 2005 LR3 yet), so though I could contribute some data/facts to this.
Problem: fuel gauge on my 2005 LR3 says empty with yellow flashing light starting 3 months ago. Started fairly suddenly, within a couple days it went from fine to "hmm does my tank have a leak" as I look at an unusually low gauge, to "nope something along the fuel level sensor/sender circuit is bad".
Diagnosis to date: using my GAP IIDTool I've determined that sender 2 is giving a continuous 4.97V (not sure how to convert to Ohms as i don't know the current), and from looking behind the back of the front passenger wheel well cover, it appears the connector and wires are fine (I don't see any rubbing on the frame horn, and I don't see a broken wire).
I have two current problems: a) I can't find the wiring diagram for this circuit, anyone have the wiring diagram for 2005 LR3? I've seen some useful stuff for other years and models, but I haven't seen one that makes sense for mine yet.
b) I can't get the connector apart! I see that the red tab slides 'forward' and 'backward' (away from the connector pair), but I can't figure out how to separate the two halves. I've tried wiggling/jiggling really hard, I've tried a little prying, but I don't want to break anything or compromise the integrity of the weather seal, so any help (e.g. video) of how to separate the two halves of this connector pair would be greatly appreciated.
My plan temporarily is to put a 50 Ohm resistor in parallel with the fuel tank front fuel level sensor/sender, as on another thread I saw that doing that allows the fuel level logic to begin working again (with just the rear sensor/sender-- presumably with inability to compensate for incline).
Thoughts? Any help?
Thanks,
Ken
KenG
Huntsville AL
Here's the GAP IIDTool screenshots of fuel sender with key on/engine off, in case they are useful.
Sender 1 shows 2.89V and fluctuates like I'd expect a functioning mechanical sensor to fluctuate (with for example some small amount of slosh in the tank). Sender 2 shows 4.89V (oops not 4.97V), and stays rock solid flat-lined, as if the sensor is not working and it is just reading some voltage regulator output from the battery (all electronic, no mechanical measurement noise).
