2012 Range Rover Warped Rotors?
Timster
Sunnyvale, CA
Anybody have any issues with the front rotors warping?
I’ve owned my RR for about four months and I have a little over 7600 miles on my it. The steering wheel is starting wobble when braking.
I started noticing the wobble this week. I drive allot and have had to brake hard a few times due to traffic. I’d hate to turn the rotors so soon. Does anybody know if this is a known problem?
Tim
PALR4
Your dealer will give you new rotors under warranty, although sometimes a slightly unbalanced wheel can move the pads back away from the rotor, which will create a vibration when you first hit the brake pedal...
For the newer full sized RR, you will get alot more discussion over at rangerovers.net.
Mouse
I have a 2012 RR. It's about 5 months old and has 5,900 miles on it and iti just started doing the same thing. I notice it more when braking from high speeds. Seems to be getting worse too.
PALR4
If you notice it mostly when first braking into an off ramp from the highway at higher speeds, you might want get your wheels balanced first...
STQAddie91
