95 Country Classic interior water leak..any ideas?
C
corb66
Hi,
I have a 95 country classic SWB that I bought for my wife to drive to the store and back. I got in it the other day and noticed that the driver side floor well was soaked and it had not rained in a while. After pulling the carpet up I noticed that the carpet pad was totally black and molded and some areas of the metal pan had started to rust. The soaked pad was only on the floor and not up on the center console. Any ideas of where to check?
Thanks
B
bigtimer24
Have you checked to see if your heater core gaskets are leaking. I had that problem on my 98 RR. Just a thought.
Could also be the A/C drain vents... happens on the Disco's all the time
Moose
Nothing about the leaks, but I have to mention that an RRC owning friend of mine insists that I point out every time someone calls them a "Country."
It's "County."
No big deal, and my bet is on the A/C drain vents.
roverman
LOL, just don't forget the 'o' or the ladies get really ******. If it was your heater core and it has been leaking long enough to cause rust, then you wouldn't have heat. Put me in the drain vent camp.
R
rishi
Leaks
I have the same problem with my '95 RRC. It is clean water in my case so it doesn't come from the heating or cooling system. I have checked and cleaned the 2 overflow pipes for the airco, no problem there.
I now believe that the problem is with the windscreen. In the right hand top corner (viewing from outside) I have noticed that the windscreen seal is loose and when I push it water comes out. I am not yet sure what to do. The simple solution would be fill it with a suitable kit, the ideal solution would be to reseat the windscreen.
Hope this helps
Regards
Rishi
I would take it by a local windscreen shop and have them reseal the windscreen.
B
borg115
Water Leaks...
I have a 1999 Range Rover HSE with a massive water leak in the back hatch. I have narrowed the leak to the rubber seal on the back window...however I am still having a the water leaks. Is there anything that I am missing? Any help would be greatly appreciated.
Hap
It's "County."
***??? I think that should be mentioned more often! I can't believe I missed that - it's like I own a whole different truck now...
p.s. - sorry to resurrect an ancient dead thread. I'm making my way through the archives, and found this one just astonishing.
