(97 4.0 V8 Discovery 95,000
jscott11
All of the sudden Tody my rover started to overheat watched the needle climb while setting at a light. I mmediatly pulled off as advised by Joey. As I tried to get home I noticed if I turned the Ac off temp would immediatly drop and If I turned back on it immediatly got hot again. Please help. Jimmy
98Disco
Check that your electrical fans are working, sounds like they might have failed. easy check start up the truck and turn on A/C the elec fans should come on immediatly and run continusly. they are mounted right behind your front grille
Agreed, the electric fans may have failed... also check to make sure you are not low on antifreeze.
SulliMtn
