ace red warning
discobuks
I've identified what i thought to be prob also cleaned and replaced ace filter still warning light beeps for two minutes then stays solid red. Will aLR dealer have to reset the system??????? Suggestions for a newbie Thanks
I don't know a lot about ACE, as I avoid buying them since they are a pain to keep happy and will make lots of noise (this doesn't mean it doesn't work).
Give Nathan a call, his site is in my signature I am sure he can offer advise on ACE.
Disco Mike
First, how many miles on the truck and have you ever changed the fluid before? Is the fluid still swirling around in the reservor?
Any Rover shop that has a high end scanner with Rover software, should be able to read the code. You will most likely have a failure requiring a repair before clearing the codes.
discobuks
Disco Mike MY disco 2 1999 has about 120000 miles on it Ive noticed in my readings this tend to be the High dollar repair zone thankful for any advice
Disco Mike
So, has it ever been serviced? Is the fluid still swirling in the reservor?
You can get good deals on used parts if needed, but you have to find out what is wrong with it by getting the codes read.
Disco Mike
Have some look at it, not the dealer and get back to us with the estimate before you jump into anything.
