Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I've identified what i thought to be prob also cleaned and replaced ace filter still warning light beeps for two minutes then stays solid red. Will aLR dealer have to reset the system??????? Suggestions for a newbie Thanks
I don't know a lot about ACE, as I avoid buying them since they are a pain to keep happy and will make lots of noise (this doesn't mean it doesn't work).
Give Nathan a call, his site is in my signature I am sure he can offer advise on ACE.
First, how many miles on the truck and have you ever changed the fluid before? Is the fluid still swirling around in the reservor?
Any Rover shop that has a high end scanner with Rover software, should be able to read the code. You will most likely have a failure requiring a repair before clearing the codes.
So, has it ever been serviced? Is the fluid still swirling in the reservor?
You can get good deals on used parts if needed, but you have to find out what is wrong with it by getting the codes read.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
