Alignment Spec
D
Doclin
Does anyone know the factory alignment specs.....F/R Toe/camber ???
2005 LR3 SE7
Thanks
grommet
Front Castor: +3° 45'
Front Camber: -0° 20'
Front Cross Camber: +0° 45'
Front Individual Toe: -0° 05'
Front Total Toe: -0° 10'
Rear Camber: -0° 10'
Rear Cross Camber: +0° 45'
Rear Individual Toe: +0° 03'
Rear Total Toe :+0° 05'
Rear Driving Axis: +0° 00'
Those are the design targets, according some aging documentation. You might want to check with your dealer to verify.
D
dalexiou
Can alignment be done anywhere or does it have to be at a Land Rover dealer? Thanks.
JohnKel
I do believe that there is a TSB dated early Oct 06 that changes the front/rear toe specs to improve tire wear issues, but lost the copy my dealer gave me after I had my alignment done at a Goodyear store.
The TSB stated that all adjustments must be done with a full tank of fuel and suspension set in Diagnostic mode IIRC. HTH
Cheers
John
JackMac
Revised alignment spec from TSB Number: TECLA2040052 Issued: Tue, Oct 3, 2006
Front total toe: +0.03
LH rear toe: +0.18
RH rear toe: +0.18
Rear total toe +0.36
nwoods
LH rear toe: +0.18
RH rear toe: +0.18
I'm not very knowledgable on this, but to a layman, that looks like a significant change?
matthewmi
So I just discovered my right rear tire is bald on the inside 2 inches. Will the new spec keep it from eatting the replacement tire?
Thanks
Matt
2005 LR3 SE
R
roverlander
TSB LA204-008 Discovery 3/LR3 - Uneven Tire Wear
Vin range: 5A300259-6A403382
However, note that dealer may not provide loaner/enterprise for TSB work. Mine gave a hard time before giving a comp rental (I had no ride!). Hope this is helpful.
JackMac
Rule # 1 of owning a Land Rover: Make sure you have another vehicle to drive too.
Rule # 2 of owning a Land Rover: Have a sense of humor. You'll need it.
