alignment
dragan
Hi i need help.:frown:
i have small vibration from 55 to 65 MPH, i balance and rotate my tire and vibration is still there. last week i did alignment and vibration is back :frown:.
if my tie road is bad or suspension will bi difficult to do alignment .if yes why LR shop didn't found problem:confused:. any suggestion.
thanks
Alignment won't cause or fix a vibration. Could be a bad drive line, tie rod end or suspension bushing.
dragan
Thanks Mike i agree whit you but to be able to do alignment drive line,tie road and bushing need to bee good or not.
Can you do alignment whit bad tie rod.
Thanks
CMGRover
Maybe the tie rod wasn't bad enough to stop them from doing the alignment...
Most 4Wheelers only have a toe adjustment and as long as the guy doing the work is any good, he should have seen a bad joint.
dragan
OK
I need to look for new tire . If is rewriting ok mast be GY tire,i have flat spat every morning .Maybe my tire cosign all those problems.
I will tell LR dealer to check again next week on my 75000 mile service.
