Amount of oil
chrisduet
Just bought this truck so I am going to change the oil. MY stick shows overfill on one side, but it needs more on the other. How much oil does a discovery 2 require? 1999 Discovery 2. Fully synthetic Royal purple 10w-30 with wix fliter
Thanks Chris
Chongo
Amount of oil
Thanks Chris
My book shows a 99 Disco to hold 6.5 quarts, but I recommend using the dipstick as your guide. Also the dipstick tube may need to be cleaned out so the stick gets an accurate reading, I use a 20” long 1/4” or 3/8” diameter wire pipe cleaner for this task.
Any questions about oil click the link below:
http://www.landroverworld.org/forums/showthread.php?t=11763
Good luck……… Chongo:bandit:
chrisduet
Hey thanks,
I went ahead and put six quarts in it. I think my tube is giving me a worng reading like you said. It shows to much on one side of the stick, but perhaps the accurate measurement on the other. Then when I put it in the opposite way it is the same.
I have also read some filters are larger and so you may have to put more oil in. So, I will see later today if i can clean it out.
Thanks
BCNJ
