Are My Subwoofers blown?
KMA
Hi there
I have a 1999 Disco 2 with a standard Harmon Kardon speaker system
Lately I have been experiencing problems with my woofer--it sounds like its rattling and sometimes it sounds as if someone is like shaking something, etc, etc.
Now I have a few questions:
1)Is the woofer blown?
2)If not what is the problem, and the cheapest/most convenient way to fix it
3) Also if the woofer is blown, I was planning on upgrading the woofer/amp system
which one would I have to buy--and also if I had the current woofer fixed--could I do something with a new amp?
I know it sounds a bit confusing but any help would be appreciated
Thanks!!
issacd
Same thing here
Hi there
Thanks!!
I had the same issue. My 2000 D2 made the LOUDEST rattling sound in the back door when the radio was on. In my case it turned out to be rust/corrosion along the bottom of the door that left the outer skin and the inner door frame rattling against each other. I put in some hot glue, just to separate and cushion the two parts and it did the trick.
Garage Tool
Hi there
Thanks!!
The subwoofer surrounds on my 00D2 were rotted. I ordered new surrounds online for around $24. I took an hour or so to take everything apart, clean off the old foam and glue new surrounds on. While I waited for the glue to dry, I straightened out the dents in the grille with a block of wood and gave it a shot of satin black.
Overall results are that the speaker looks and sounds 80% better. Still goes all flappy on deep base when the spatiial is on, but that might be an amp issue.
Rome0Mike
