AUX and IPOD
grommet
If the Navigation voice had a fixed volume adjustment, it wouldn't bother me so much... I could live AUX being a slightly lower level. (I think I'd be smart enough to turn the volume down before switching sources.) But having the voice directions attempt to pop your eardrum while using AUX is just irritating... almost dangerous. :smile: So voice assist gets turned off. Ugh.
A
alanmeyer
grommet said:
If the Navigation voice had a fixed volume adjustment, it wouldn't bother me so much... I could live AUX being a slightly lower level. (I think I'd be smart enough to turn the volume down before switching sources.) But having the voice directions attempt to pop your eardrum while using AUX is just irritating... almost dangerous. :smile: So voice assist gets turn off. Ugh.
This is a very annoying feature of the LR3. In my Nissan w/Nav, the system uses a *fixed* volume level for the voice prompt. In the LR3 it varies with the stereo volume. Also, the LR3 settings don't allow for a negative value relationship between the radio and the prompt.
So, I just turn off the voice prompt as well.
In my opinion, the proper way to implement voice prompting is to keep the prompting at a fixed level with possibly using the speed-sensitive volume adjust to compensate for road noise. In addition, the ability to toggle voice prompting on/off should be added to the main map page once a destination is active, instead of being 1 menu level down.
-Alan
allodial
GROMMET: Hey man, i know you probably have said this a million times.. and ive noticed you would be the one to ask... i have the base lr3 with the aux on the head unit.. but no aux in behind the console... i thought i saw that you had wired up the back of the unit through that emtpy slot? you would make my year if you could copy and paste any of your posts you think could help.... have been searching forever and bugging my dealer...
thanks, any help would be much appreciated..!
grommet
allodial, yeah... I documented that long ago... as have others. If you didn't find it already, I'll look again... just a couple of wires and you are ready to go.
