luckystrike
- Joined
- Apr 29, 2013
- Posts
- 2
- Reaction score
- 0
Hey
first post, I have read here before and never needed to post until now.
I have a 2006 LR3 HSE, around 88K mi.
anyways, noticed a crystallized mist on my back window on the freeway. checked and noticed coolant sprayed all over the frame, checked under cover and this little Tee bleeder or vent valve was cracked on both ends.
right after a 250mi trip back from vegas. was about 100 degrees, so I am certain it was heat that cracked it. and why LR decided to make this part out of plastic? not sure.
what I would like to know is the best way to remove the plastic ends that are still broken off and stuck inside the hose, I dont really want to chew it up and get plastic in the line.
also does a all brass version of this valve exsist? what coolant do you guys use?
sorry for the noob questions
Thanks
Thanks
